1st gear
Old Jan 5, 2005 | 07:54 PM
  #31
Default RE: 1st gear
its better than locked up tires. itll probably still slide a lot, but better than slammin the brakes.
Old Jan 5, 2005 | 10:34 PM
  #32
StifflersMom's Avatar
Cat Fuсker
Should work on snow too. But will it work on ice?
It does work on snow, but if you're unkucky enough to get on ice with less than 70% thread compression braking doing about 20mph I wish you luck...and a clear road ahead of you...
Old Jan 10, 2005 | 11:32 PM
  #33
94VTECoupe's Avatar
My car is hard to put into first too. when I brake, I just put the brakes on until the engine is at around 1,500 RPM then downshift to save wear on my clutch parts. I only do this if I'm rounding a corner or something, otherwise I just put it in neutral if I'm coming to a stop. I don't put the car back in first unless I'm from a stop. I even use second when I'm parking my car in the garage going 5 MPH... However, if I shift really quick from first to second there have been some instances where the gears ground before engaging. I just jammed the stick too hard though, lol I know better now.
Old Jan 10, 2005 | 11:53 PM
  #34
Super Mario's Avatar
That is EXACTLY ME. I do the absolute exact same thing. If i would have written it down thats what i would have said!
Old Jan 11, 2005 | 03:18 PM
  #35
XCM828's Avatar
ORIGINAL: Super Mario
I bet he's psychic or something.
Old Jan 11, 2005 | 10:49 PM
  #36
I'll bet.....
Juans_MX3
Apr 9, 2010 05:37 AM
andybuck711
Mar 3, 2010 07:14 PM
MasterJT
May 18, 2008 05:37 PM
Apostle
Jan 7, 2008 03:30 PM
Tomo!
Apr 28, 2006 02:02 PM
