how
Old Feb 19, 2006 | 12:22 PM
  #21
Josh's Avatar
Default RE: how
a deer feeder battery weighs 12lb. and is about a 1/3 the size of a car battery would it work
Old Feb 19, 2006 | 01:35 PM
  #22
05reverb's Avatar
Default RE: how
yes it would work but will drain faster. but it all depends how high you'll be listening to your amp and how long. anyways, the more you put in parralelle, the longer it will last. be sure not to connect it in series cause it add all voltages from each battery.
Old Feb 19, 2006 | 01:54 PM
  #23
Remmy's Avatar
Default RE: how
^ hes right. When a bus would come into the shop wed start cussing because we had to convert the battery power. It was almost as bad as on old volvos [:@]
Old Feb 19, 2006 | 02:03 PM
  #24
Josh's Avatar
Default RE: how
would 2 12volt deer feeder batteries put in parralelle with a recharger hooked
up to it work
Old Feb 19, 2006 | 02:04 PM
  #25
05reverb's Avatar
Default RE: how
yes
Old Feb 19, 2006 | 04:11 PM
  #26
05reverb's Avatar
Default RE: how
here, i found a power supply that can handle 40 amp continuous, 50 amp max, but it's over 300$ canadian
http://www.radioworld.ca/powersp/pyramid.php#ps52k
i only have the ps-7kx on my table, it can handle 5 amps continuous and 7 amps max.
the ps-52kx can handle 40 amps continuous and 50 max, wich would be good enought to power a small amp
Old Feb 19, 2006 | 05:22 PM
  #27
Josh's Avatar
Default RE: how
would 1 12volt deer feeder battery with a recharger hooked up to it would it work
I have a 300wat max power 150 wat rms amp
Old Feb 19, 2006 | 10:06 PM
  #28
Josh's Avatar
Default RE: how
BUMP.[sm=insomnia.gif]
Old Feb 20, 2006 | 11:22 AM
  #29
Josh's Avatar
Default RE: how
[sm=gears.gif]
Old Feb 20, 2006 | 01:57 PM
  #30
05reverb's Avatar
Default RE: how
yes it would work, but might be hard on the charger.
