how
Old Feb 20, 2006 | 05:10 PM
  #31
amg6975's Avatar
Default RE: how
http://www.etronics.com/product.asp?...re=&catid=4158
There ya go. Do it right.
And all the talk of 24V systems... I just read an article that was about car companies trying out and testing 48V systems. As an electrical guy I can say that 48V systems would be really cool, no need for massive amounts of current anymore. I honestly don't see it happening in standard gas burning cars though. Maybe hybrids will move to a full higher voltage system though.
Old Feb 20, 2006 | 06:09 PM
  #32
05reverb's Avatar
Default RE: how
yeah higher voltage systems would be cool. wouldn't need big *** wires for our amps. but it would be a very big problem, cause all car accesories and stuff is all made to run on 12 volts right now, so by making a car that would run on 48 volts, they would have to have accesories made to run on 48 and some to run on 12 volt.
Old Feb 21, 2006 | 10:33 AM
  #33
Josh's Avatar
Default RE: how
would it be hard on the amp if I used a 24v battery
Old Feb 21, 2006 | 03:59 PM
  #34
05reverb's Avatar
Default RE: how
you can't use a 24 volt battery on an amp, it is designed to run on 12 volts.
Old Feb 21, 2006 | 06:27 PM
  #35
Josh's Avatar
Default RE: how
OK[>:]
Old Feb 22, 2006 | 10:49 AM
  #36
jusplayn85's Avatar
Default RE: how
Take a house plug that's 12 volt, cut the end off... wire the ground and power to the amp... and there ya go... lol That's how I have a few bars of neon wired up in my house.
Old Feb 22, 2006 | 11:04 AM
  #37
Remmy's Avatar
Default RE: how
If not done properly that can cause big problems
Old Feb 22, 2006 | 12:00 PM
  #38
jusplayn85's Avatar
Default RE: how
Yeppers... Just gotta make sure it's the correct volts and all the good stuff. Had em goin for about 2 years and everythings been fine. Gotta love that "ricer" under couch neon look... lol.
Old Feb 22, 2006 | 03:55 PM
  #39
05reverb's Avatar
Default RE: how
what are you talking about, a house plug that is 12 volts???????????????????? it's 120 volts?????
Old Feb 22, 2006 | 03:58 PM
  #40
05reverb's Avatar
Default RE: how
are you talking about a little transformer that plugs in a wall outlet and changes voltage to 12 volts???? if so, that will not handle the load of the amp, those thing can handle i think at max around 3-5 amps tops. it's ok for neons, but not for an amp.
