Worst thing you have done to your civic
Old Jan 12, 2008 | 06:18 AM
  #71
WipLash's Avatar
Default RE: Worst thing you have done to your civic
+1 on bad cupholders.i had a large coffee from dunkin donuts ad the cupholder mad a tear on the bottem of the cup so a whole steaming hot coffee gone everywhere.[sm=smiley35.gif] anyways worst thing i think is ebay short throw shifter,clear corners and even tho i love my loud car i hate cops :P
Old Jan 12, 2008 | 07:23 AM
  #72
Fiirkan's Avatar
I'm putting this where it should have been a year ago
Old Jan 26, 2010 | 12:54 PM
  #73
MistaGlock's Avatar
got to the traffic light. stuck out a little bit into the intersection to do a left turn. light turned yellow but i didnt wait to see if ALL cars were stopped. turned and this bitch comes flyin at me.
Old Jan 26, 2010 | 02:55 PM
  #74
inthezoneac's Avatar
Not a rice thing, but a suspension thing lol
When I lowered my civic, instead of using the tapered washers from the stock front struts I used the flat weaker washers from the KYB bump stop/strut mount kit. Diagrams showing how to put the front struts together showed flat, non-tapered washers to sit on the shaft area, so I just assumed I was doing the right thing. And at the time I thought the tapered washers were part of the strut (a slight tap with a hammer popped them off)
Well a couple months later I hear this clunk coming from the front end after work. I pop the hood and see this:
I'm like wtf my strut busted. Well a couple phone calls later, a guy from KYB told me about the tapered washers. I bought a new front strut since I damaged the adjustable dial at the top and decided to check out the passenger side front strut.
Sure enough the washer that sits on the shaft was starting to bend. Probably a couple more days for the washer hole to widen and have the same problem repeat.
And with the strut sticking out like that, I almost put a hole in the hood. There's a slight upward dent, which started to rust and that was one reason for me to get a new hood
Never worked on a car before I got mine, but I get valuable lessons from it.
Old Jan 26, 2010 | 03:24 PM
  #75
Dipsetcivic117's Avatar
lol. i did the same exact thing. hit a pothole and heard a pop. and kept hearing a popping noise. looked my hood and seen an upward lump on it. surely enough, when i looked under the hood, there was my shock shooting out.
Old Jan 26, 2010 | 03:28 PM
  #76
PunisherInOKC's Avatar
Man, I hate to see another EF hatch torn up. =/
Worst thing I've done was a few years back. Was on campus at OSU. They have some large speed bumps. I hit one at 60ish MPH for ****s and giggles. Got soo much air, and bottomed out hard. Ended up breaking the rear crossmember.
Old Jan 26, 2010 | 05:10 PM
  #77
I did the opposite thing. Apparently, hardcore slammage and low-profile tires cause a car to ride rough enough to literally shake bolts loose. The strut bolt, to be exact. One day while driving, I kept hearing a popping sound over bumps... opened the hood and my strut had worked its way loose and was actually under the strut tower. Ended up bending up the strut pretty good, so I ended up buying another one. It worked out since my struts were starting to leak anyway; apparently, KYB AGX struts can't hold up to a 3"+ drop
Old Jan 26, 2010 | 05:33 PM
  #78
stuco's Avatar
Originally Posted by FlipHKD720
again, laughing my *** off
haha and yea, the cuphodlers are horrendous. They're not deep enoguh for anything, even like cans
I was just reading the owners manual the other day and it actually says to only use the cupholders while parked! Haha, I haven't had an accident yet with mine but they are in a weird spot.
Old Jan 26, 2010 | 06:25 PM
  #79
1995CivicEXBMF's Avatar
Putting the LED tubes on he bottom of my car, you can see them and i broke the front one not once but twice so im going to take them off and lower my car
Old Jan 26, 2010 | 07:07 PM
  #80
Dontoh's Avatar
worst thing i did it to? bought it one of the previous owners gave me a lot of dirt on it, didn't wanna hear it, but i had to
