z6 or y8?
Old Mar 2, 2007 | 08:08 PM
  #21
skateman190's Avatar
Default RE: z6 or y8?
Z6, akmee head package, new gaskets, new water pump, new timing belt, cable tranny, stg2 exceddy clutch, 11 to 13lb flywheel, and a tune on a p28
ok so your reccomending a mini me with a new si tranny and p28 chipped or sumthin?
Old Mar 2, 2007 | 10:02 PM
  #22
Marty's Avatar
a whole z6
Old Mar 2, 2007 | 10:21 PM
  #23
so why would i need a new water pump and timing belt(and whats the akmee head package)?
Old Mar 2, 2007 | 10:47 PM
  #24
Marty's Avatar
new water pump and timing belt because it is prevenative maintence www.akmee.com they have a head package for Z6's that is making around 140whp for $525 shipped.
Old Mar 2, 2007 | 11:28 PM
  #25
sounds good and all but ....
AKMEE Engineering's parts are NOT CARB approved. It was designed for FOR OFF-ROAD USE ONLY. It is the purchaser's responsibility to check and comply with all local, state, and federal law.
Old Mar 3, 2007 | 01:02 AM
  #26
Kedawei's Avatar
How is carb going to check that? It's all internal.
Old Mar 3, 2007 | 09:27 AM
  #27
i thought when they do emissions and inspections they might be able to catch it,(i guess not then)
Old Mar 3, 2007 | 09:34 AM
  #28
Marty's Avatar
if you have the correct tune the only time it should fail would be under oart/full throttle.
Old Mar 3, 2007 | 09:42 AM
  #29
ok, it might not even be a prob then i forgot i have a buddy that does emissions and inspections
Old Mar 3, 2007 | 09:52 AM
  #30
what about pistons and all? would you reccomend i bore it and but better pistons, rods, etc.? im not wanting to cheap out and only do the top end.
