z6 or y8?
Old Mar 2, 2007 | 12:01 AM
skateman190's Avatar
Default z6 or y8?
ok im swappin a d series in my car after all but i was wondering which motor has more potential d16z6 or y8?
Old Mar 2, 2007 | 12:05 AM
ic892003's Avatar
Default RE: z6 or y8?
from what i hear the d16z6 is the way 2 go
Old Mar 2, 2007 | 12:06 AM
blackmetal619's Avatar
ive heard z6, but i say y8
Old Mar 2, 2007 | 12:12 AM
b8teen's Avatar
i like the signature...
Old Mar 2, 2007 | 12:28 AM
ic892003's Avatar
ORIGINAL: b8teen
[sm=smiley20.gif]
Old Mar 2, 2007 | 01:13 AM
FlipHKD720's Avatar
both are about the same, i beleive the z6 is OBD1, which means it has a chippable ECU, which could be a plus in the future if your lookin to boost. So i say z6 ftw
Old Mar 2, 2007 | 08:25 AM
riceburner700's Avatar
z6 ftw
Old Mar 2, 2007 | 09:11 AM
Street Sniper's Avatar
They are pretty close, but it depends on what you want to do. Generally speaking, the z6 is better for boost and the y8 is supposed to be better for NA apps. The z6 head has tumble ports and the y8 has swirl ports. The y8 also has.4 higher CR then the z6 which is a plus for NA but makes the z6 a tad more boost friendly. The JDM D15B has a better rod/stroke ratio than either which will give you more revs and the head is the best flowing of the 3. It's also ~ 100lbs lighter than it's USDM counterpartsbut you are giving up over 100cc's of displacement.
Old Mar 2, 2007 | 09:51 AM
Marty's Avatar
the D15B head is a exact copy of the Z6 head, both are P08 stamped, both have the same cam in them
Old Mar 2, 2007 | 09:58 AM
ORIGINAL: Marty
Hmm, there is some conjecture about this. I personally have both cams and I can tell just by looking at them that they are not the same cam. Both heads are stamped p08 but does that necessarily mean theyhave the exact same flow characteristics?
I'm not gonna argue with you. It's splitting hairs either way, but I have read several opinions that suggest differences.
