Engine Swap b18?
Old Apr 19, 2008 | 08:37 AM
and_so_we_went's Avatar
Default Engine Swap b18?
hey i need some sugestions, i just blew the third cyl. in my b16a2 99civic si. wondered what you think of budget wise, for a good engine swap.
im thinkingLS b18, and keep my vtec head. whata yah think?
thanks andy
Old Apr 19, 2008 | 12:22 PM
Default RE: Engine Swap b18?
ls vtec can be a reliability problem. I would use a gsr or ITR block.
Old Apr 21, 2008 | 08:56 AM
why reliability?
gsr is like 3500dollars i cant swing that!
Old Apr 21, 2008 | 09:14 AM
jamned's Avatar
From what I understand, the LS connecting rods are longer, so they'll be subjected to more force on every rotation than the c-rods on the b16 and b18 setups. If you're not going to rev high, this might not be a problem. You could also get aftermarket rods. The gsr and maybe the itr have oil squirters near the oil pump to better lubricate the connecting rods and main bearings. This helps at the higher rpms that the gsr and itr were made for (I guess?)
Both of these links are pretty quick reads and tell you what sort of failures you'd see with the ls/vtec setup. It looks to me like it's all in the rods, pistons, and rod bolts. If you're looking for a daily driver and won't drive it to high rpm, maybe you could start with stock parts.
http://clubintegra.com/board/showthr...rid&t=1857
http://www.honda-tech.com/zerothread?id=1362978
Old Apr 21, 2008 | 09:46 AM
devney's Avatar
ls/vtec can be very reliable. It's all in the build.
Old Apr 21, 2008 | 03:32 PM
XxDrummerxX's Avatar
Did you want to get a civic engine, or a swap for like a, integra or something?
Old Apr 22, 2008 | 08:53 AM
i have a 99civic si with a b16b2 in it and i just cooked my third cylinder so i want to swap with a b18b2 96-00. i plan on rebuilding my valves, you know pollish and port those babys! its practly 4-5bolts! its gona be sweet but knowing what other people think is gona weight my desition.
Old Apr 22, 2008 | 05:34 PM
no, its 3500 for a whole swap. all you need is the shortblock. under 1000, easy. maybe way under, I havent shopped them in awhile.
Old Apr 23, 2008 | 08:50 AM
yah your right for a short block but its really hard to find a short block nowa days, if you know of a sight or somewhere to shop help me out but i cant find nothing!
The Stig 199
Jul 18, 2011 12:56 PM
Redline25
Dec 15, 2007 08:56 PM
stang
EK Swaps
Aug 22, 2005 12:24 AM
grncivicvtec
Mar 18, 2005 08:23 PM
grncivicvtec
Feb 25, 2005 01:12 PM
