stereo wiring on 94 DX??
Old Apr 22, 2008 | 04:37 PM
civic94dx's Avatar
Default stereo wiring on 94 DX??
hi im wanting to put my aftermarket headunit in to the civic,but theres no harness adaptor so i need to know what colour wire is which?so if anyone has a diagram or just knows what each colour is for then it would be appreciated.thanks.
Old Apr 23, 2008 | 07:32 AM
chunkbird's Avatar
Default RE: stereo wiring on 94 DX??
What? No harness for the radio or to the car? I have an aftermarket harness from my last stereo I had in my 95 Civ. I got it at Best Buy - if you looked there.
Old Apr 23, 2008 | 07:35 AM
All Civic harness adapters are the same over a wide range of years.
The only reason not to use a harness adapter is if some ******* before you had already cut the factory plug out.
Old Apr 24, 2008 | 01:30 AM
jim9418's Avatar
Old Apr 24, 2008 | 03:07 PM
civic94dx's Avatar
well basically the factory harness has been cut off, so all im left with is alot of loose different coloured wires which i dont know what each is for. so what i need to know is which colour is which so i can bullet plug them into the aftermarket harness that has come with my stereo. i dont have a clue which colour is for the remote wire either as im trying to connect an amp. ???
Old Apr 25, 2008 | 06:31 AM
Read your head unit manual to see about the remote wire. It is almost always either blue or blue with a white stripe. You need to run a new wire from the head unit to the amp for the remote. There is no remote wire in the factory harness.
Old Apr 25, 2008 | 12:14 PM
well best if you would go to a junk yard and buy the radio harness and put it back on the car correctly... that way you have the right colors and then you can use the aftermarket harness adaptor.
i dont see why so many jackasses cut that **** off! the adaptors are only like 10bucks!!!!!! but still idiots think they can do it......
now it may not be correct but this is the info i got for my 94 when i bought my alarm...
Old Apr 25, 2008 | 02:35 PM
civic94dx's Avatar
ok thank youfor your help everyone,im going to try go down the scrap yard and find the orginal harness.ill keep you updated with the progress.thanks again.
cowsgonemadd3
Apr 5, 2007 05:32 AM
SkeetFresh
Aug 16, 2006 06:51 PM
SkeetFresh
needs more salt
Jul 10, 2006 11:34 PM
Polygamy16
Apr 18, 2006 10:49 PM
