new wheels rubbing-need opinions
Old May 4, 2008 | 05:37 PM
nation's Avatar
Default new wheels rubbing-need opinions
http://www.performanceplustire.com/p...345#prodAnchor
i just put these on a 99 ex with the idea of putting them on my 99 si.i plan on lowering it about 1.5" but im worried.right now they rub in the corners.now the ex does have 165k on original struts/shocks but still im worried with new hardware and a lower stance they will rub.17x7.5 w/40mm offset.opinions? oh and its a 205/40 tire
Old May 4, 2008 | 06:04 PM
Default RE: new wheels rubbing-need opinions
lowered or stock suspension?
and where is it rubbing? front rear, during dips, or dips while turning, or just turning at slow speed?
the tire size looks ok tho the wheels are 7.5 mine are 7wide and i dont rub in the front with stock suspension and only slightly rubbed when lowered on my TEIN Stech springs in the front when turning and hiting a dip, tho i did have to roll the rear fender lips to make them clear when i had the car lowered on the stech springs......
Old May 5, 2008 | 04:49 PM
With a +40 offset with 7.5" wide wheels, I'm guessing you're probably going to rub when you lower it... you can roll the rear fender lips, but that's about all you can do short of getting new wheels (again).
(and addiction, he isn't rubbing yet, he wants to know if he will be rubbing)
Old May 6, 2008 | 07:41 PM
nation's Avatar
well i lucked out. les schwab is just going to put new rims on,no charge
Old May 7, 2008 | 07:24 AM
KarTuneMan's Avatar
New wheels with proper fitment..... what a concept.
I worked for Schwab's for 10 years. This was MANY years ago, and as you can see there are still a few guys in these stores that
do not know how to do plus fittment. They calculate the correct tire size but pay little to no attenntion to the specs on the wheel.
99% of the "help my wheels rub" posts you read here, are from improper wheel fittment.
Old May 9, 2008 | 03:50 AM
nation's Avatar
picked up a set of enkei or52.love them and not to heavy.
mask_k
Aug 31, 2011 07:54 PM
ballinboy1020
Feb 8, 2009 10:38 AM
shortlid
Jul 13, 2007 01:15 PM
408spike t
12
Jul 8, 2007 08:35 PM
bleedhondos
Apr 18, 2005 02:55 PM
