02 civic LX 1.7 coupe - break light help plz
Old Aug 27, 2006 | 07:56 PM
browndude's Avatar
Default 02 civic LX 1.7 coupe - break light help plz
my rear right break/stop light does not work. lamp isn't the problem, installed a new one, going to check the fuse. anyone know which fuse i should be looking at? I'm a complete newby..
Old Aug 27, 2006 | 10:06 PM
browndude's Avatar
Default RE: 02 civic LX 1.7 coupe - break light help plz
allright this is an embaressing question..
where is the fuse box in a 02 civic LX 1.7 coupe :-S
Old Aug 27, 2006 | 11:03 PM
Chimera02EX's Avatar
There is one fuse box under the hood, if you are standing infront of the hood it will be on your left hand side above the battery, it will be a covered plastic box, pop the lid off and on the underside it will tell you what fuse is what. There is also a fuse box under your drivers side dash, below your steering column you'll see a panel with two twist release locks undo those and you'll have access to that panel.
I wish I could be of more help but I do not know which fuse you require off hand, I did a quick look in my Chiltons and didn't see anything about it, but if I find it tomorrow or later this week I'll update you on it.
Old Aug 28, 2006 | 07:30 AM
baker's Avatar
mine does that occasionaly but just on the passenger side. i just wiggle the wires behind the light until it works
KFRG
Feb 7, 2010 03:28 PM
andrew58201
Apr 18, 2009 05:50 PM
FastCat
Jan 20, 2008 05:14 AM
that_guy5
Feb 9, 2007 08:09 AM
03civiclxcoupe
Jan 5, 2007 10:49 PM
