spoiler break light connection?
Old Jan 5, 2007 | 05:57 PM
03civiclxcoupe's Avatar
Default spoiler break light connection?
put my spoiler on 03 civic lx coupe....now i just need to know how to connect the break light on the spoiler and disconnect the stock break light on the rear deck...
any1
Old Jan 5, 2007 | 06:28 PM
Method's Avatar
Default RE: spoiler break light connection?
this is coming for my 92.
if you look in trunk and look up, you can see the wires, to disconnet them, and tape them separte so they don't short out. and for hooking up you spoiler light, just tap in to one of your other lights. theres probaly abunch of lights, look in your manual to see which wires which.
Old Jan 5, 2007 | 10:49 PM
Stumasters's Avatar
I am going to get a type R spoiler, kind of factory looking, but I have that gay third brake light already. When I look inside the trunk, and look up on the roof of the trunk, if you will, I see the harness going to that third brake light in the window. I am going to cut those wires, leaving enough room to re-connect them if someone someday wants to, and run those wires to my new spoiler. They should supply sufficient power for most any light. You can probably match the wires, most brake light wires are black and black with a silver or white stripe. If you can't match them you can always check your manual for wiring, or use a cheap tester light to find the hot/ground when someone's pushin the brake pedal.
B_Ray
Feb 24, 2021 11:23 AM
KFRG
Feb 7, 2010 03:28 PM
CivicStreetRacer97
Sep 27, 2007 07:06 PM
Vexorg
Apr 9, 2006 10:19 AM
Super Mario
Nov 22, 2004 01:03 AM
