07 Civic 4dr. amp install question
Old Dec 26, 2006 | 04:41 PM
dookie's Avatar
Default 07 Civic 4dr. amp install question
I know this may be a stupid question, but has anyone put an amp and subs in a new civic. If so, where did you run the power wire for the amp through the firewall. I have been under the dash and under the hood and cannot find any thing to run it through. PLEASE HELP!!!
Old Dec 26, 2006 | 07:09 PM
Carlz0r's Avatar
Default RE: 07 Civic 4dr. amp install question
You'll probably have to make your own hole.
Old Dec 26, 2006 | 10:14 PM
03civiclxcoupe's Avatar
im pretty sure under the passenger side front wheel well if u take off the coupel clips or scres holding on the black plastic covering thing theres a rubber thing in a hole in there...takea screwdriver and poke a hole through that and push the wire thoruhg make sure the wire is tight inside it tho so water cna't get through
Old Dec 28, 2006 | 03:39 AM
dukat03's Avatar
for AUTOMATICS- there is a small 4 gauge knock out panel on the driver side firewall where the clutch would go if it had one or its also located to the top right of the break booster .
for STANDERDS- between the brake booster and front driver side strut tower
97LXmcfly
Mar 13, 2012 05:22 AM
civic96lx
Jan 17, 2009 09:22 AM
magiconthetire
May 28, 2007 09:17 AM
Cdude
Jun 25, 2006 10:51 PM
mmohon
Jun 13, 2005 08:53 PM
