2000 DX stereo install help..
Would i be better off if i just went ahead and took my deck to a car audio shop to be installed?
I know next to nothing about car stereos.. and i don't want to screw anything up.
Do it yourself. It's so easy. There are several threads on here explaining how to do it on a 6th gen. You just start unscrewing lower dash panels, pull all 3 out, unscrew a few bolts from underneath the center console core support, then pull the center console out, disconnecting some stuff in the process. If you can be comfortable enough with removing panels, you can do it.
The 2000 is real simple since the stock radio is standard DIN sized, the same size as aftermarket ones. Get a harness adapter so you don't cut any wires in the car. You wire the adapter to your new radio, then unplug the old one and plug in your new one via the adapter. You don't have to modify anything on the car at all, simply disassemble, swap out radio, and reassemble.
pictures are nice too..
https://www.hondacivicforum.com/foru...ad.php?t=68735
Your removal/install will actually be easier than this because it's on a 2000 and this is from a 96-98.
