96 Civic Hatchback Front Speakers problem!
Old May 9, 2012 | 01:02 PM
prestonf's Avatar
Default 96 Civic Hatchback Front Speakers problem!
Hey everyone, I'm having a little trouble with my Honda Civic 1996 CX Hatchback.
I've been told and I've done my research and apparantly my front speakers are 6x5. So I purchased a pair of Alpine type s speakers for the front and rear.
The rear speakers went in perfectly and sound great, but the front speakers seem like they need a lot more room to fit in.
Even if they fit in, the screw holes don't match the ones on the speakers.
Does anyone have a solution for me? I'm very new to all this car stuff lol
Thanks!
Old May 9, 2012 | 04:41 PM
ChristianL's Avatar
I had a similar problem with the door speakers in my '97. They ended up being about 1/4" larger in diameter than the stock ones, so they required some trimming to fit. Mine were also deeper than stock, so I had to do a lot of trimming to get them to fit inside the OEM plastic basket. In the end, most of that nicely-designed factory shielding was cut away, but the speakers fit flush and you'd never know they weren't stock.
Don't expect the screw holes to line up, though. That's pretty typical of aftermarket speakers. In the past, I've used self-tapping screws, and even small bolt/nuts to cinch them down in some cases.
Old May 9, 2012 | 11:15 PM
Turtlegrip's Avatar
all this.
if it is too small then you can make a round wood ring that screws into the door and then the speaker can screw into that.
Old May 17, 2012 | 01:23 PM
Slen17's Avatar
another option you can do is a bracket mount directly onto the door panel. It sounds risky, but it frees up room for the magnet, and still maintains quality sound. That is counting that you have your panel secured...
alstonfered
Jan 30, 2010 05:34 PM
RyanM923
Oct 9, 2008 04:45 PM
jbriley3
Jun 22, 2007 10:51 AM
sandjstickney
Apr 18, 2007 11:01 PM
ScrooLoose
Apr 11, 2007 07:52 AM
