Amp install kit
Old May 12, 2005 | 01:08 AM
bigindian869's Avatar
Default Amp install kit
Hey, I was wanting to install a couple of amps in my car. Was wondering if any of you know a good place to find multi-amp wiring kits for a really good price. Is there anything I should look out for thats special about certain types. I imagine a power wire is a power wire (I've cut into a 4 gauge Monster wire and there didnt seem to be anything special about it, like in there home audio stuff). Anyway, any input would help.
Old May 12, 2005 | 08:14 AM
Remmy's Avatar
Default RE: Amp install kit
Monster wire is a joke. Its like the 'Bose' of speaker wire, its expensive and every average idiot thinks its special. I need to know what kind of power you are going to be running, normally for 2 amps a tad over 300 watts, your going to need 4 gauge from the battery and than a splitter a.k.a. distribution block and 8 guage to the amps.
( http://www.partsexpress.com/webpage....7&filter=block ). If your amps are more than 400 watts a pop, id go with 2ga wire from the battery to a splitter and then 4 gauge to the amps.
Old May 12, 2005 | 11:20 AM
I won't be running anything too powerful. My basic setup is that I have a Type R 12 in a ported box, powered by the Alpine MRP-M350 amp....which pushes 350 watts RMS and 700 max. However, I found that the sub with ported box makes plenty of power, so usually the gain on the amp is around half or just under. I don't have new speakers yet, but I have the MTX 6304 4 channel that I want to use once I get my speakers. I believe it pushes around 50x4 RMS. I was thinking the 4 gauge split into 8 gauge, I believe thats how it was set up on my old car. I also have a 1 farad capacitor sitting around, so I figured I'd throw that into the mix.
Old May 12, 2005 | 01:04 PM
Remmy's Avatar
Youll be fine with the 4 to dual 8 guage setup, trust me, your amp will never see 700 watts... not even in its dreams.
Old May 13, 2005 | 12:58 AM
yeah, didnt think it would....dont think I want it to for that matter
Old May 13, 2005 | 07:40 AM
Roost3r's Avatar
ORIGINAL: remington870_20ga
very very very very true. im gonne alot of home sound installs as well, copper is copper...no difference to it.
if you are doing a mulit amp. set up. ur going to need a multi wire batt. connection, and you might wanna get a yellow top batt if you can afford it, just so you dont stess ur cars electrical system
dookie
Dec 28, 2006 03:39 AM
Cdude
Jun 25, 2006 10:51 PM
Offspring
Jan 19, 2006 02:24 PM
xjbmx
Oct 16, 2005 06:03 PM
mmohon
Jun 13, 2005 08:53 PM
