amp for rockford stage 3?
Old Mar 15, 2007 | 09:05 AM
03civiclxcoupe's Avatar
Default amp for rockford stage 3?
for this sub
http://www.cardomain.com/item/ROCP312D2
what kind of amp should i get to power it perfectly at its RMS
usually i kno this stuff but the 2 ohm voice coils confuses me
do i get an amp that is 500x1 rms at 2 ohms?
Old Mar 18, 2007 | 02:23 PM
klownkiller's Avatar
Default RE: amp for rockford stage 3?
with the sub @ dual 2 you could wire it up to be 4 ohm or 1 ohm. therefore, you would need an amp that pushes 500w at either 1 ohm or 4 ohm.
Old Mar 18, 2007 | 06:25 PM
civic96lx's Avatar
somethin like this...
http://www.cardomain.com/item/ROC06P5502
Old Mar 18, 2007 | 06:32 PM
Stumasters's Avatar
To get 500 watts at 4 ohms you will need an amp that will push 1000 watts of RMS power at 2 ohms. If you pick up a dual 4 ohm speaker instead you will save hundreds on an amp.
CivicNooby00
Mar 21, 2007 02:42 PM
03civiclxcoupe
Dec 31, 2006 11:00 AM
03civiclxcoupe
Dec 3, 2006 09:08 PM
peacebwithyou
18
Jul 10, 2006 12:00 PM
chaseman1978
Oct 29, 2005 08:04 PM
