audio help
Old Jun 12, 2007 | 09:43 PM
triggerstep's Avatar
Default audio help
hi, I need some info or help with a few things.Do I need a cap,battery,alternator in order to run the following companents.They are all pioneer premier components.amps sub-PRS-D3000SPLand a 4chnl-PRS-D4100F,subs 2-TS-W2501D4: Dual 4 ohm. fronts-TS-C130R-backs-TS-D691R.Deck-DEH-P780MP.Do I need a alternator-batery and a cap.I have a 98 civic ex.I know the alt is about 70amps.Any help would be great.What do you guys think off xstatic products?
Old Jun 13, 2007 | 07:42 AM
jeff948594's Avatar
Default RE: audio help
put it in and see if your headlights dim, if they dim you make the call on what u want to do, 98's still have the tiny lil battery i think and something we do at work is relocate a full size Optima battery to the back, caps dont always work but are usualy the cheapest option, alternators make a world of difference though. hook it all up and let me know how bad your headlights dim if at all.
i have never used xstatic stuff.
Old Jun 13, 2007 | 08:30 AM
mlobitz's Avatar
Member
You could also replace the big 3. Sometimes that will allow enough current to flow that you don't get the dimming headlights and whatnot....
Old Jun 13, 2007 | 08:33 AM
thi3v3z's Avatar
im running a diamond 15 on 750w, along with a 4 channel pushin 300w . Im running 1050w rms in a 00 ex. All i did was upgrade the big three, bat-gnd, eng-gnd, and alt-batt, and put in a optima in the back, and i have no problems with my alternator keeping up, or the lights dimming. Caps are a waste of money, and alternators are expensive. Just wire up a 2nd battery.
JimmyClone
Oct 7, 2006 08:57 PM
civicfan87
Jan 2, 2006 01:21 PM
tampacivicguy
May 2, 2005 12:47 PM
hisokano1
Apr 6, 2005 12:25 AM
D16z6
Feb 10, 2005 05:27 PM
