buzzing noise
Old Jun 20, 2004 | 09:12 PM
GWhiz's Avatar
Default buzzing noise
when i play my radio or cd...i get this buzzin noise...its an engine interferrance...i already tried those ground blocker relay things....and it still there...anyone got a clue on how to get rid of it?? maybe a new set of hyper grounds will work??
Old Jun 21, 2004 | 02:58 PM
NTX's Avatar
NTX
Default RE: buzzing noise
You running an amp with subs? If so be sure the power wires are run seperatly from the other wires. If not, could be wiring behind the deck or ignition interferance. A good set of plug wires might help.
Old Jun 21, 2004 | 04:04 PM
green98lxsedan's Avatar
double check all your hookups ide say. make sure the ground is good
Old Jun 22, 2004 | 01:38 AM
ohbiskits's Avatar
I had the same problem when i first hooked up the system... it was the grounds...be sure there all good
.......good luck
Old Jun 22, 2004 | 03:45 AM
GWhiz's Avatar
grounds to what?? the engine or the system?? i've done a new ground on the engine...and it still makes that sound...
Old Jun 22, 2004 | 07:07 AM
polo708's Avatar
ORIGINAL: ntxmotorsports
I'd bet that is exactly what it is... its your power wire (from your amp) running too close to your speaker wire... My cousin has that problem but hes too lazy to fix it. Just re-run either of the two to a different location away from eachother.[sm=smiley2.gif]
Old Jun 22, 2004 | 02:20 PM
ohbiskits's Avatar
check all of them but i think it would have been the engine because if its the ground to the system / amp/ your bass wont hit... the ground to my system was pulled out and the amp/sub hookup stoped working... i guess if you checked the gronds then thats not the problem...
good luck with the problem.
Old Aug 15, 2004 | 08:43 AM
eggie75's Avatar
yea, first check ur grounds... if you grounded on a painted surface, did you grind off the paint? make sure ur power wires aren't run near speaker or rca's. gl.
plba1126
Feb 16, 2011 11:17 PM
shokwave
Jul 8, 2007 01:43 PM
Belmont
Dec 26, 2005 01:23 AM
titusbyronicus
May 29, 2005 08:41 PM
CivicEX98
Jan 22, 2005 12:35 PM
