buzzy sound evem with car off HELP!!
Old Apr 14, 2007 | 09:57 PM
madjoker14's Avatar
Default buzzy sound evem with car off HELP!!
sup guys,i got this big problem and the reason why i say this is because ionly 1 driver seat and barly anything inside the car,i toke it apart to find out why it is making this buzzing sound even when the car is off,when i turn the car on i hear nothing but the alternator in the speakers,now i toke the head unit apart and re wired the wired to the speakers n amps but the buzzing is still there,now aruff lay out of my sound system is 4 speakers 2 amps (1 2000watt and 1 300 watt) i got a capasitor a distibutor block,no matter what i do thebuzz is there,can any one help me,thanks for any info in advanced
Old Apr 14, 2007 | 10:35 PM
madjoker14's Avatar
Default RE: buzzy sound evem with car off HELP!!
well let me sum it up,it buzzez when the car is off,kinda loud do you guys think it might be a bad ground,RCA issue here??
Old Apr 15, 2007 | 08:33 AM
theonecalledtodd's Avatar
most likely RCA's are running near your other wires or maybe bad grounds, check both of those before doing anything else as those are the cheapest ways to go.
[align=left] [/align]
Old Apr 15, 2007 | 09:48 AM
madjoker14's Avatar
okay i'll check that when the rain stops puring but also could it be possible that the amp itself that could be cousin the the buzzing sound if damaged? and also thanks for the info
Old Apr 15, 2007 | 11:09 AM
the727kid's Avatar
I am going to take a guess, and say you have a Pioneer HU?
If so that is a common issue for them. Re-ground the HU to the chasis, and sand it down to shiny metal. IF that doesn't help get some 18 gauge wire and wrap it around the RCA outputs ont he HU and screw the wire down to a screw on the back of the HU.
Old Apr 15, 2007 | 05:45 PM
madjoker14's Avatar
yup good guess and what your saying is to just ground it right out on the body of the head unit? at least the ground for the headunit to itself pretty much,if im understanding this correctly
Old Apr 15, 2007 | 06:16 PM
the727kid's Avatar
Here check out this link... http://www.caraudio.com/forum/showthread.php?t=198477
Old Apr 25, 2007 | 03:45 PM
madjoker14's Avatar
wow that worked perfectly man,thanks for all your help n pulling outa this hole,if you dont mind me asking how does this happen,like what couses this,how does the rca jack like interfear with each other?
Old Apr 25, 2007 | 04:53 PM
the727kid's Avatar
To be honest I'm not sure how it happens, I just know it's common on Pioneer HUs. But glad to hear that worked, I figured that was the problem.
Old Apr 25, 2007 | 09:07 PM
03civiclxcoupe's Avatar
could the be the problem with my alpine
