cd changer mounting location??? 4dr
Old Feb 22, 2006 | 08:32 AM
campbuds's Avatar
Default cd changer mounting location??? 4dr
1996 Civic 4dr.
I am trying to decide on a mounting location for a 10 disc changer. I don't want to hang it from the top of the trunk. Under the passenger seat would be nice but it doesn't fit. Then I checked on mounting it off to the side of the trunk floor (behind drivers tail light) but then I run into 2 issues. First the floor there is not flat for mounting and the carpet is laying there and needs to be able to move when accessing the spare tire.
Any recommendations?
Old Feb 22, 2006 | 09:45 AM
Remmy's Avatar
Default RE: cd changer mounting location??? 4dr
I did this when I had my changer. I made a plate for it to mount on from the structure of the trunk right behind the carpet.
Old Feb 22, 2006 | 10:41 AM
campbuds's Avatar
Maybe some more details on that... or also I am still open to ideas on other mounting spots.
Old Feb 22, 2006 | 11:58 AM
Remmy's Avatar
You need to get a plate of thin aluminium and tapping screws. I even used washers to balance the plate. Once you have that you will have a flat mounting surface. You might need to predrill the holes because the luminum might bend if you apply too much pressure. I reused mine for an amp.
Old Feb 22, 2006 | 12:39 PM
Remmy's Avatar
Ill get you a hi res pic in a second.
97LXmcfly
Mar 13, 2012 05:22 AM
banf
Aug 12, 2007 09:36 PM
superfestiva
13
May 26, 2006 04:20 PM
oldschool
Mar 20, 2005 09:25 PM
NYC Civic
Jun 9, 2004 06:06 PM
