DOME LIGHT?
Old Feb 26, 2008 | 02:04 PM
silverbullet01's Avatar
Default DOME LIGHT?
i have a 98 civic ex and i have a after market cd player and now my dome light doesnt work in my car. anyone have a stock radio i will buy off or how do i fix that problam??
Old Feb 26, 2008 | 06:53 PM
Stumasters's Avatar
Default RE: DOME LIGHT?
Did you check the bulb?
That doesn't seem like a radio problem. Check your fuses and your bulb. Also check the switch for dust.
I haven't been paying attention to posts recently, but I am fairly sure there wouldn't be an issue wiht the radio.
Old Feb 28, 2008 | 06:57 AM
StarMarbury03's Avatar
i have a 96 ex with an aftermarket cd player in...do you have keyless entry on your car? if so does it work....because for mine i had to hide the old deck in behind the dash....it was a pain in the ***...search around
Old Feb 28, 2008 | 08:14 AM
gin0o0o's Avatar
The wiring in your car was likely done wrong. They have harnesses that state right on the package to be able to work with the domelight. Also, if you have a stock keyless entry system on your car it would make a difference. Like StarMarubury03 said you might have to reinstall your stock radio and hide it behind the dash for everything to work properly.
Old Feb 29, 2008 | 08:50 AM
mja988's Avatar
there is a work around that someone posted on this forum. I used it as well because I had the same problem. I'll see if I can dig it up. I remember it consisted of bridging a green wire.
Old Feb 29, 2008 | 09:39 AM
Shbek's Avatar
First off, does the light work when you have it in the on position, but not when you have it in the middle (door open) position? If thats the case, then its very easy to fix. I actually just fixed this in my car a couple of hours ago. You need to take your stereo out, now, there should be two green harnesses. Find the one with the light green w/black stripe wire. It'll be on one side of the harness. Now, on the same harness, same collum, but on the other side and three spaces over, there will be a light green w/red stripe wire. You need to get a small piece of wire, and insert one side into the lt. green w/black and the other side into the lt. green w/red. Should fix the problem. If it doesn't, you may need to clean the contacts on the door that trigger it.
addiction2bass
Feb 25, 2008 01:24 PM
titusbyronicus
May 29, 2005 08:41 PM
WrongfulWright
Apr 4, 2005 06:26 PM
redgst
Apr 3, 2005 01:09 PM
