DRL disable
Old Aug 18, 2007 | 10:57 AM
goixiz's Avatar
Default DRL disable
Is there an easy way to disable the DRL but all the functions of the light in park and headlights still function ?
Old Aug 18, 2007 | 04:21 PM
civicduty96's Avatar
Default RE: DRL disable
not that i'm aware of ...i'm pretty sure it's controlled by the BCM
Old Aug 18, 2007 | 05:49 PM
dito.... if anything ya might have to rewire the headlights completly.. wire up 2 relays off the battery and use the stock switch to control the relay and run the power output wire from the relay to the headlights.... low beams and highbeams. use the one as low beams and one for the highbeams...
or ya might only need to do one high or low... not sure how the DRL lights operate off of... i think only one but not sure if it runs off high or low beams... test light is your best tool.......
Old Aug 18, 2007 | 06:39 PM
goixiz's Avatar
been searching and reading
seems like fuse #37 if removed from fuse box will disable DRL
Old Aug 19, 2007 | 07:08 PM
KarTuneMan's Avatar
On the 06 and 07 this is correct. It's a 7.5 amp.
dobbs
Apr 3, 2009 03:57 PM
liljohnny
Oct 8, 2007 07:15 PM
apexer
Apr 8, 2006 03:02 PM
britben
Mar 25, 2005 10:11 PM
red4kat
Nov 14, 2004 11:12 PM
