DVC wiring
I want to wire one 4-ohm DVC subwoofer bridged on channels 3/4 of my amp. The amp is only stable when bridged for 4-ohms, and all the wiring diagrams I have seen for a single DVC woofer present a 2-ohm load. How can I wire this up? Thanks!
Option 1 (parallel) = 2 ohm load
Voice coils wired in parallel
Recommended Amplifier: Stable at 2 or 1 ohm mono
Option 2 (series) = 8 ohm load
Voice coils wired in series
Recommended Amplifier: Stable at 4, 2, or 1 ohm mono
here are your options....this or get another woofer!
With a dual 4 you can only do 2 or 8 ohms, if you had 2 dual 4vc subs you could do 1ohm or 4 ohm.
With a dual 2 you can only do 4 or 1 ohms, if you had 2 dual 2vc subs you could do .5ohm or 2 ohm.
So if you have to get a total of 4 ohms for the amp, you either need 2 dual 4ohm subs, or 1 dual 2ohm sub.
00civiclx
Sep 30, 2004 04:48 PM
vk4bcp
Jul 6, 2004 03:31 PM
