fog light trouble
Old Feb 26, 2008 | 07:33 PM
cyberx32's Avatar
Default fog light trouble
Bought crappy ebay lights (yeah i know) so they worked fine until one of the bulbs blew out. So i replaced it and the old bulb lights up and you can see the new one lights up half as strong then the fuse blows. Its a 30 fuse. Would i risk starting a fire if i use a 40 fuse?
Old Feb 27, 2008 | 08:28 AM
gin0o0o's Avatar
Default RE: fog light trouble
The answer is yes. Recheck the wiring and make sure you don't have any shorts. That is most likely your problem.
Old Feb 27, 2008 | 05:24 PM
cyberx32's Avatar
Im pretty sure its not a short. cause one light will work just fine, but when i try with both bulbs it blows the fuse
Old Feb 27, 2008 | 05:32 PM
you sure ya got the right bulb?
and is it a regular bulb or one of those immitation HID color bulbs? if its a fake hid bulb ive heard they pull ALOT OF JUICE to power them!
but another thing to check out is unplug the good bulb and put the new bulb in that fog light and see if its still half lite and try the old bulb in the other sides fog light, if the dim stays on that one side of the car with both bulbs then its wiring, if the bulb is still half lite on the other side then you could just have a faulty bulb thats shorting out internaly..... its a posibility, just swap the bulbs around to eliminate the posible stock wiring short.
Old Feb 27, 2008 | 08:21 PM
cyberx32's Avatar
Yeah i actually ought some hid wannabes first and it just blew the fuse, then i went to the store and bought some regular ones and it still blew. I wanna try putting that higher fuse in, but i dont wanna risk burning my car up lol
Old Feb 27, 2008 | 08:49 PM
gin0o0o's Avatar
Did you check the wiring. I know one of the bulbs work sometimes but seriously check for a short somewhere.
Old Feb 27, 2008 | 09:04 PM
cyberx32's Avatar
well i dont wanna check right now, its too damn cold outside, but ill keep you guys updated.
Old Feb 28, 2008 | 08:15 AM
gin0o0o's Avatar
Oh I'm with you on that. This weather right now is ridiculous.
Old Mar 7, 2008 | 11:28 AM
cyberx32's Avatar
ok i changed the fuse to 30 (thats the one the set came with) then i turned it on and went to the front of the car, both foglights were on and bright, then after like 5 seconds one turned off and the other one got really dim, it stayed that way for like 5 more seconds then the fuse blew. So i tried a 40 fuse, none of the lights turned on and when i went back to the car, the fog light cables were smoking. Im guessing it will be some wire touching bare metal or wiring got screwed up somehow?
CatsnotCars
Jan 28, 2015 12:24 PM
2000civicEX
Jul 22, 2005 10:00 AM
RadTek21
Jul 2, 2005 03:06 PM
nitsuj1604
Jan 17, 2005 10:31 AM
spevie
Oct 6, 2004 02:10 AM
