front speakers no sound
Old Aug 17, 2006 | 12:25 AM
thedougler's Avatar
Default front speakers no sound
Front Speakers arent working...they are hooked up in back of headunit and the speakers must be in between?
Old Aug 17, 2006 | 12:52 AM
psychocivic's Avatar
Default RE: front speakers no sound
have you ever replaced the wires going from the HU to the speakers? if not, run new wires and see if that helps. and also just make sure you don't have the settings set up to where no sound is going to the speakers, simple but common mistake.
Old Aug 17, 2006 | 12:25 PM
Ej1Rider's Avatar
and also make sure the terminal on thw back of the speakers isnt touching any metal part of the door or where ever the speaker is cuz that have happened to me before
Old Aug 17, 2006 | 01:42 PM
thedougler's Avatar
no my fade is set half and half right now, i will look into checking out the wries and if the terminals are touching the door panel
Old Aug 17, 2006 | 02:28 PM
Ej1Rider's Avatar
secure all wires and metal from terminal...... then while the speakers out of the door panel...put couple of layers of black tape around the holes for the speakers
Old Aug 17, 2006 | 04:29 PM
01silverbullet's Avatar
if they are stock speakers replace them (if you can) while you are at it and you will be glad you did....
cowsgonemadd3
Feb 24, 2010 08:59 PM
alejo97Cx
Sep 16, 2008 03:17 PM
TTrevGoSaints
Mar 7, 2008 10:11 PM
Parolee
Oct 19, 2006 12:23 AM
cowsgonemadd3
Aug 18, 2006 08:02 PM
