Good Amp/Sub?
200-300$ Budget
http://www.frys.com/product/5594310?...H:MAIN_RSLT_PG
For 300$ good buy?
What would you reccomend for a 99civic dx 2dr?
For 300$ good buy?
im using a 800watt 2ch amp and one 12 and it sounds real good. have you check your local CL but beware make sure they hook everything up and show you it plays and nothing is blown. or dont buy it.
50$ =/
-->http://sandiego.craigslist.org/nsd/ele/1353097493.html
sounds good to be true? or may have problems?
-->http://sandiego.craigslist.org/esd/ele/1353846759.html
this is great too, what are the pros and cons of watts?
rms watts is the true power of the amp... if a amp says like 1100 watts thats the peak power.... its best to go by rms all you need is like a 600 watt amp and 2 10's or a 800watt 2ch or mono and 1 good 12. used systems are fairly cheap... there is a local kid here that has 2 sony xplode 10's and a 1100watt sony amp for 150$.there are alot of good brands to look for and there are brands to not buy. just search for what is near you and post and we will try to help u. but if you go to buy anything make them hook it up first. or no cash tell them!
Fusion RE-PK1120
12" Single Voice Coil 4-Ohm Subwoofer
With 450W Amplifier
Kit includes:
* Max power: 600 Watts
* RMS power: 250 Watts
* Frequency response: 30 Hz - 320 Hz
* Impedance: 4 ohms
* Sensitivity: 89 dB
$200 bucks.
good buy?
With 450W Amplifier
Kit includes:
* Impedance: 4 ohms
$200 bucks.
good buy?
what are 1 channel amps?
and 5 channel amps? Don't see what the difference is about.
EDIT: -->http://www.frys.com/product/5946014?...H:MAIN_RSLT_PG
That's the Fusion 96civichb, i find it as a good price what do you think?
Whats my best bet with an amp to give me a nice kick and bass wobble (250$ limit) =/
Source:Fry's at the moment
EDIT2: -->http://sandiego.craigslist.org/csd/ele/1351226235.html
4 channel amp? maybe lower down to 250$ and get a 50$ 12 sub?
(somebody explain difference between 1 channel - 5 channel amps please, thank you)
EDIT3: -->http://sandiego.craigslist.org/nsd/ele/1346249688.html
Sounds like another good deal, what you think?
EDIT4: -->http://sandiego.craigslist.org/nsd/ele/1352182167.html
Guy sounds reliable, and the price sounds unbeatable. any pointers as to which sounds good?
the last 2 links seem good.. try the 3rd link and offer hi 175$ cash.. but make sure he hooks them up.. feel the sub push it in a little to check the stiffness it shouldnt be real soft and flimsy or make and scraping noises or be stuck
