ground wiring
Hey all,
I'm just about to hook up all my audio components for my civy, and I was looking on the internet for a good wiring diagram for capacitors. Anyways, I was on the homepage of the capacitor that I have and I came across this...
"In order to reduce the chance of ground loops (i.e. engine noise); make the grounding wire as short as possible to reduce the wire's resistance. Also, when using multiple components, make sure all units are grounded at the same point."
Now I've got 2 amps and the capacitor, (1) should I be running all of them to the same ground point? or just the amps together and the capacitor seperate? or all 3 seperate?
Also just to make sure, (2) I run the posative power cable from the car battery to the capacitor, and then that same wire from the capacitor to the posative of the amp? I think this is correct, if not please tell me.
Oh and finally, (3) what's the easiest method of charging the capacitor before connecting the posative cables (the capacitor needs to be charged before connecting).
So yeah, I always feel so random when asking questions, there's three of them in there.
Thanks for you time
B
Thanks for you time
B
i usually use seperate ground points, BUT, i have used one before. i ran a piece of 0/2 (or 2/0...it's been a while) from a ground point and ran it to a non-fused distribution block and then ran 2 smaller wires off of it. just keep them short. if it were me i would do each one seperate, but that's me. it's your car you can do it either way you want.
2. that will work fine
3. lol, i've hooked up a couple by just throwing the juice to them. you get a big spark, i wouldn't recommend it though lol. best way is through a resister. it's been so long since i've messed with a capacitor in this sense i dont have any suggestions as to what size you should get.
you want to help even more, upgrade your "big 3" wires, get a bigger altenator, better battery, or all the above.
Hey thanks matts,
What can I use as a resistor? I already have a capacitor rated at 5 farads so that's good to go. It came with a small LED light I think, but it was broken when I recieved it. Should I just go and snag another one? or is there something else that I could be using.
Also, I was wondering...can I hook my single capacitor up to 2 different amps? They're both for my subs one is rated at 800 watts and the other only at 200. Will something like this damage any of my components or am I good to go?
Thanks again
B
Thanks again
B
well if ya wanna hook up a cap... they are usualy just crap... waste of money if ya ask me!
BUT if you realy wanna run the cap to charge it up alls ya need a some type of 12volt light.....
either a 12volt test light.... or just a dome light bulb.... just conect the ground wires up to it and then befor ehooken up the positive power wire touch the power wire to the one side of the light... then touch the other side of the light onto the positive terminal of the cap.... it will lite up and then when the light goes out its charged..... then just screw the terminal down withthe power wire and your golden.....
well at least it wont spark.LOL
BUT your largest dimming problem will be from your factory ground wires!
upgrade those and you should fix the problem! caps are CRAP just missing the R.LOL
caps dont help your voltage issues! lets face it...... what is the problem of the dimming... not geting enough power... and to get enough power it also needs enough grounds....
upgrade two wires and if your alternator can handle your amplifiers then the ground wires is all you need which is still cheaper than a cap.LOL
upgrade the wire from your battery to the cars body.... and also either extend a wire from the battery to the engine block or you can just try replacing that 2ft section of wire from the front rad support to the powersteering brackets
but i upgraded my ground wires from the battery to the strut brace and from the strut brace ran to the power steering bracket.... helped my dimming alot but my alternator just isnt big enough to handle my amplifier.LOL so it preaty much shuts off the alt on about 3/4volume.LOL
you also need to upgrade the wire from your alternator to your battery as well. use at least 4gauge wire for all the upgrades.... those are usualy good up to 1K watts.... BUT your alt might not handle it.... LOL i know its strugling to handle my 1200watts.
BUT trust me/us........... if your runnen under 600watts just upgrade all your stock wires and it should fix the problem!
just think about it... a cap is total BS... cause the capacitor has to charge before it can discharge... while it discharges befor ethe second bas**** the cap has to recharge which inturn starves the amplifier of power while it recharges... so on and so forth.... which is why it sucks.... it just starves your amp and helps it for a second. just think about it....... you ever seen any true competitors using caps? NOPE... they either use larger batteries.. or multiple batteries. and also use high power alternators as well as the upgraded wires...
thats 50bucks you could spent so much beter!
a cap is like a bandaid IMO. if you've got a little dimming it'll take care of it. if the lights are almost shutting off with every bass hit then you need to reevaluate the situation. a cap will level the voltage going to the amp. and yes, it will drain almost instantly, but it recharges at about the same rate. so the lack of juice going to your amp is going to be minimal. anymore i use a cap with a digital readout for show. is it functional? yes, but i've also got a upgraded alt, wires, and a 2nd battery, so the gain i see with using it is nill.
but if you've already got it, then yes, you have it hooked up right. there's not really a wrong way to hook it up as long as it's connected to the battery and grounded. you actually don't even have to have it hooked to an amp for it to work.
hoody1982
Jun 22, 2004 06:49 PM
