help with tach in gauge cluster
Old Apr 23, 2009 | 03:51 PM
93CIVICB20B's Avatar
Default help with tach in gauge cluster
hey i have a 93 civic ex and i recently put a new gauge cluster in and this 1 has a tach in it but the cars original one didnt have one so the tach isnt working because there isnt a wire, how do i wire the tach up??
Old Apr 24, 2009 | 10:09 AM
You may have a bad cluster. I'm pretty sure that all models are wired for a tach even if they didn't have one originally. It would be a blue wire leading to the cluster.
Old Apr 24, 2009 | 12:10 PM
ya the cluster should work no problem. ive swaped it before.
Old Apr 24, 2009 | 03:51 PM
yea thats what i thought at first but then i put it in my other 94 civic which had an original tach and it worked perfectly fine.
Old Apr 24, 2009 | 03:56 PM
maybe some one cut the tach wire before on the car... only thing i can think of.
Old Apr 25, 2009 | 12:21 AM
Isn't there a sensor inside the distributor that gives the tach the signal? Perhaps the sensor in the distributor is bad?
Old Apr 25, 2009 | 09:24 AM
well ive been looking around and askin ppl and im thinking that maybe i could run the wire from the cluster to the distributor and splice into 1 of the wires that would run the tach but the problem is idk the wire i need 2 splice into? so does ne1 think that would work?
Old Apr 25, 2009 | 10:44 AM
On a stock '93, the tach wire is the small wire from the distributor plug with two wires. The tach signal comes out of the ICM on a pin dedicated for that purpose. Check that wire for continuity back to the cluster and shorts to ground.
If you have an engine swap, someone may have forgotten to hook up the tach wire in the harness.
Old Apr 26, 2009 | 01:30 PM
alright thank you
eqmassa
Jun 21, 2011 04:41 PM
country
Mar 28, 2007 12:48 AM
ProjectGSR
Mar 13, 2007 08:32 PM
mickiemagik
May 17, 2006 09:12 PM
millertime17
Jun 26, 2005 09:38 PM
