Honda Civic 03 problem
Old Mar 22, 2008 | 01:42 AM
kyokyo's Avatar
Default Honda Civic 03 problem
hi~ i have a problem with a honda civic 03, im trying to install a new cd player into it~ but we are not able to get a wire harness so we had to hard wire it.
But now... the CD player only starts up while making a... buzzing?? cd reading kinda noise.... the screen of the cd player wont turn on etcetc... @@"
also the central locking has stoped working? is this a result of that?
any help... would be appreciated thanks XD
Old Mar 23, 2008 | 07:16 PM
KarTuneMan's Avatar
Default RE: Honda Civic 03 problem
You can bet there is a problem in your wiring. Double check!
+12V DC Battery(Constant)
White/red
Pin A10
10 amp
Fuse box at right side of engine compartment
Switched Accessory
Yellow/red
Pin A2
7.5 amp
Fuse box under left side of dash
Ground
Black
Pin A20
Illumination
Red/black
Pin A9
Dimmer
Red
Pin A19
Left Front +
Green/black
Pin A7
Left Front -
Light green
Pin A17
Right Front +
Green/black
Pin A8
Right Front -
Light green
Pin A18
Left Rear +
Blue/white
Pin A6
Left Rear -
Blue/black
Pin A16
Right Rear +
Pink
Pin A5
Right Rear -
Blue/yellow
Pin A15
Old Mar 25, 2008 | 10:41 AM
kyokyo's Avatar
hi~ thanks for your reply, i was wondering if you could explain a bit futhur? on where i have to check, what i have to do~
because i matched up the old wiring to the colours
Old Mar 25, 2008 | 01:13 PM
bakertime's Avatar
I think he's suggesting to double check all of your connectors. Did you solder them? If not you may have a loose connection also.
Old Mar 25, 2008 | 07:27 PM
macbeth18288's Avatar
Did you looks at best buy for a wiring harness?
Or online??
Old Mar 25, 2008 | 08:02 PM
cyberx32's Avatar
Sometimes you cant just color match the new radio to the car harness. check the colors he listed up on top. It should be wired that way.
Old Mar 28, 2008 | 06:51 PM
Mr. B's Avatar
Goodness. Get a wiring harness off ebay. I'm a car audio professional and I would never attempt what you're doing.
Slammed98silvercoupe
14
Dec 19, 2010 05:16 PM
djt
Jun 21, 2008 07:48 AM
redlines4us
Aug 22, 2006 05:49 AM
tanksOnFire
Jan 8, 2005 03:38 PM
tanksOnFire
