hooking up hids
Old Feb 26, 2009 | 09:52 PM
that_guy5's Avatar
Default hooking up hids
so i bought a kit and i was ready for install it, hooked up everything like you suppose to but they light up for a second and kinda flicker, so my question is is there another way to hook these up besides using your stock light harness?? i have egay projector that are going on, and the stock harness is 3 prongs? plz help guys thanks
Old Feb 27, 2009 | 09:19 PM
that_guy5's Avatar
cmon guys i hate to just stare at the dam things without installing them?! anyone??
Old Feb 27, 2009 | 09:26 PM
lol bump someone help the guy dam it :P
Old Feb 27, 2009 | 10:36 PM
FlipHKD720's Avatar
mm.....are the HIDs defective? Like when you hook the harness up to the standard projector headlights do they flicker?
Old Feb 27, 2009 | 10:53 PM
check your connections again. is this flickering on one side or both side? if one side see if switching the bulb or ballast works. and when it lights up or flicker is it HID light or halogen light?
Old Feb 27, 2009 | 10:56 PM
that_guy5's Avatar
i tested them both by hooking them both to the neg and pos. on the battery and they light up fine, but when i try to connect them to the stock harness they flickr for about a second like they want to light up but they dont, any more ideas ??
Old Feb 27, 2009 | 11:39 PM
lowlife9's Avatar
Banned
go to WWW.MOBILEHID.COM scroll down to the bottem and buy one of there relay harnesses good luck and next time "please stay away from ebay"
Old Feb 28, 2009 | 11:27 AM
Originally Posted by lowlife9
go to WWW.MOBILEHID.COM scroll down to the bottem and by one of there relay harnesses good luck and next time "please stay away from ebay"
yea your going to need one of those. sounds like the stock harness is not pushing enough power to turn on the HID's and the ballast is drawing too much power to start up. if that does not fix the problem then it is probably bad ballast
Old Feb 28, 2009 | 03:36 PM
dito... if they work fine on the battery its just your headlight harness isnt getting enough power to them, tho they have worked fine for me on both my civics...
but here ya go buy this and slap it on. very simple!
http://shop.ebay.com/items/_W0QQ_dmp...elay&_osacat=0
if you have bixenon hids they be sure to buy the bixenon wiring kit.
http://cgi.ebay.com/ebaymotors/HID-H...Q5fAccessories
now i cannt say which kit is the best... your judge for yourself with there feedback.
OR if you want to make your own you can with a inline fuse some wire, a relay and afew wire terminals....
tho making it yourself will cost more money than those since they buy in bulk...... so might as well just buy a built kit which should work with ease...
Old Feb 28, 2009 | 06:11 PM
one of mine flickers sometimes when you turn it on but it works in like 5 seconds so i don't care. lol
