Installing EX Cluster Problem...PLEASE HELP
Hi Guys....
I'm in need of some desperate help here. I have a 94 dx hatch. I bought a new guage cluster off ebay (because mines didn't work -- broken from previous owner). After swapping out the cluster (supposedly plug-n-play), my blinker don't work, and my car won't shut off unless I push in the "hazard" light button. I've tried disconnecting the battery..hoping to reset it, but that didn't work. I've tried unplugging everything and plugging it back in, and that didn't work. I also tried swapping the old cluster back and its doing the same thing.
Anybody run into this problem before???
Thanks
Thanks
hmm your blinker do'nt work and you have to press the hazard to shut it off? i would replace the hazard button, probably has nothing to do with the cluster
well wasn't the original cluster acting up anyway?
Was the cluster you bought new or used? Maybe the new had problems with it and thats why they were selling it
hopefully not but its always a possibility
The reason i say the hazard switch is cause that will prevent the blinkers from working. i have never heard of having to hold it in to turn the car off before though
Yea...its crazy. Everything on the original cluster was working fine (blinkers, hazards, etc..) except the speedometer needle...it was starting to "stick" (sometimes works and sometimes doesn't) It perplexes me as well, needing to push in the hazard light to shut the car off. I doubt its the new guage causing the problem, even when I switched it back to the old one...the problem is still there.
JizzleCX
13
Apr 9, 2009 05:45 AM
1998wagonhatch
Aug 15, 2005 03:36 PM
