inverted subs in box?
right now i got 2 12" memphis subs in a ported box, what i want to do is invert the subs..i got a question tho, will this work and sound as good??????????..im not sure if you can do this on a ported box, my first choice was to invert only 1 of them but i no you cant do that if they are in the same box..thanks
I belive it might be the boxes problem to hold you back. But go ahead and try it, it shouldnt be much different. To be sneaky, string the wires thru one of the screw holes to make it look pretty.
Yes you can invert them both or just one. The back of a sub sounds the exact same as the front. If you only invert one though you have to hook its polarity up backwards. THe posotive to negative and vice versa.
The only way you can invert just one is to reverse the polarity(put the - on the + and the + on the -)
As far as inverting it's just a way to show the back of your subs off it has no bearring on the output or sq
ok thanks but one other thing just so i understand this properly, i only have to change the connections - to + and + to - to the sub that im inverting, not the other one thats just reguler right??
dave_57204
Apr 6, 2008 05:38 PM
Veegor
Nov 28, 2005 06:38 PM
DeiblerDelux
Apr 22, 2005 12:48 PM
