Led Wiing problem
Old Jan 2, 2009 | 02:27 PM
Jon Steele's Avatar
Default Led Wiing problem
So i just finished wiring in some leds for the foot wells in my car and the poblem is that when i turn them on the come on for a second then go out
Old Jan 2, 2009 | 02:35 PM
Justin13's Avatar
Banned
blew fuse mabye?
Old Jan 2, 2009 | 03:02 PM
Jon Steele's Avatar
no all the fuses are fine
i hooked up a voltage tester and after the Leds go out its still saying there is a current
Old Jan 2, 2009 | 06:19 PM
civicduty96's Avatar
how do you have em hooked up? if there raw leds ( no resistor ) you need to series 4 together so they each get 3 volts .... or use a resistor on each one ...... most of the time leds are 3 volt and they'll get pissed off when you send em 12 volts
Old Jan 2, 2009 | 07:19 PM
Jon Steele's Avatar
they are 3 sets of 1 foot pre wired strips each set is wired together and fused
Old Jan 2, 2009 | 07:21 PM
what are they wired to?
Old Jan 2, 2009 | 07:22 PM
Jon Steele's Avatar
the cigarette lighter
Old Jan 2, 2009 | 07:27 PM
does it do the same exact thing every time? is the duration they stay on for the same every time?
Old Jan 2, 2009 | 07:33 PM
Jon Steele's Avatar
ya its exactly the same you have to wait a few seconds for them to come on again after u turn them on again almost like something has to reset
Old Jan 2, 2009 | 07:36 PM
damn, this is weird
i'd start by changing the fuse anyway. sometimes a blown fuse can appear to be fine. (the fuse could just have a really weak connection inside)
