Led Wiing problem
ok i just changed the fuse and it still not working if there is a bad connection it should be before the wires split up because they all flash and then turn off ?
the weird thing is is that the volt tester lights up half a second after u flick the switch and stays on and dosent go off
where did you get the leds? it might be some bad led bulbs. either that or bad connection, thats all i can think of.
for the floor lights i recommend going with led strips from oznium, you might want to look into that if thats not what you already have. flexible and can take a little beating.
ya 2 of the sets were originaly the ones u plug into the cig lighter hocked up into a splitter this was before i heard of oznium
i figured i should clean up the mess up get rid of the spliter and wire them in properly not plugged in to the cig lighter and then this problem started
