Lookin for some help with my sub
Old Jul 7, 2005 | 05:13 PM
benstalk's Avatar
Default Lookin for some help with my sub
Ok so i was driving home from work today and my sub suddenly stopped working. i got home checked all the wiring and everything seems prefectly fine and i cant seem to find anything wrong with it. I just installed it about a month ago and this is the first problem ive had, any ideas? by the way i drive a 95 lx
Old Jul 7, 2005 | 05:43 PM
Street Sniper's Avatar
Default RE: Lookin for some help with my sub
Wow, where to start.
Ok, is the amp light on?
Yes- Check the speaker wire connections on the back of the sub and trace it to the amp to make sure everything is secure.
No- Double check all connections for power and ground. Check fuses.
Amp light is on and all connections are secure as far as you can tell, no fuses blown including the one wherever the remote is run from- hook the sub up to a known good source to see if it plays and/or hook a known good speaker up to your amp.
Speaker works, amp not on = probably power supply bad = $100 to fix
Amp on, speaker no workie- blown sub = you get to go shopping
Check all of this and get back to us.
Old Jul 7, 2005 | 06:10 PM
benstalk's Avatar
ok so heres the update i did everything u said
the amp definatly has power to it
i hooked up my sub to my home stereo and it works fine
hooked my old set of speakers up to the amp and they work
so now where to i go from here the wierd thing is that when i apply pressure to the sub it starts workin but then when i let go it stops again man i am lost see if u can make anythign out of that
Old Jul 7, 2005 | 06:27 PM
Remmy's Avatar
Did you install your radio all ghetto like? If so, check the RCA wires to the amp from the radio, it happened to me once bcause of faulty RCA's . That is also a common problem.
Old Jul 7, 2005 | 06:56 PM
You mean when you press on the sub it starts workiing and if you let go it stops? Or do you mean pressure as in turning it up really loud ? Even on the home stereo?
Fried voice coil. Time to go shopping. Do you have a crossover on it or are you running it full range?
Old Jul 7, 2005 | 08:21 PM
Remmy's Avatar
ORIGINAL: Street Sniper
Yup... its not exactly fried....but more 'out of alignment'. It wouldnt work if it was completly fried. All in all... time to put on your best slicks and hit up the audio joint to put a sub in a new home.
Old Jul 7, 2005 | 08:47 PM
ngoti 8tor's Avatar
Happy shopping!
Old Jul 10, 2005 | 01:11 AM
Roost3r's Avatar
hehe..what kinda sub?
PNK SLP
Aug 26, 2007 05:19 AM
windcalmer
Aug 4, 2007 01:30 AM
Polygamy16
May 3, 2006 09:15 AM
PhatCivic01
Mar 6, 2006 12:34 AM
PhatCivic01
