Memory problems
Old Dec 21, 2006 | 11:22 AM
rmg35's Avatar
Default Memory problems
alright, so i got this new headunit (sony) and i can save all the stations and set the clock and everything, but once i shut off the car, it clears it all out the memory, and when i turn it back on, the headunit starts up as if i just bought it. what do i have to change this memory problem.
sorry if i put this thread in the wrong cat.
Old Dec 21, 2006 | 11:34 AM
Fiirkan's Avatar
Default RE: Memory problems
Did you connect the headunit with the factory harness? or did you take the lazy(but more complex) way out and wire the deck directly to the facroty harness? it sounds like the memory wire isn't connected. that or the sonnection isnt strong enough
Old Dec 21, 2006 | 11:47 AM
rmg35's Avatar
it connects straight from the wirein harness from the car to the head unit. no splicing
Old Dec 21, 2006 | 12:07 PM
2slo4u's Avatar
might be a fuse under the hood...
what about the factory clock? is it working?
Old Dec 21, 2006 | 12:10 PM
rmg35's Avatar
thats what i was thinking it was a fuse, but i have no idea of what one i should check? and there is no factory clockanywhere on the dash board. i find it kinda weird
Old Dec 21, 2006 | 12:26 PM
2slo4u's Avatar
just check all the fuses.. thats what i had to do.
Old Dec 21, 2006 | 03:13 PM
well your saying you just instaled it?
if so ya might have switched the memory and power wires...... check them with a light tester.... the large yellow wires should always have power! the red should only be powered with the ignition....
ive done that before.... best way to find out is to pull the radio and test the conections on the radios harness that goes into the radio... NOT the radio itself cause you gotta unplug it to check wires of course
what ya think?
Old Dec 21, 2006 | 04:04 PM
rmg35's Avatar
well i took it to circuit city to have it done, cuz i have no idea how to do it. but im going out now to check the fuses.
Old Dec 21, 2006 | 06:18 PM
R35P3KT's Avatar
if u got it done at CC...jus go back and tell them cuz it was obv somethin they did, but dont wait too long or touch too muchwring,cuz theyll say it was u and might charge you for it
Old Dec 21, 2006 | 09:30 PM
ya if you just had it instaled at a store TAKE IT BACK TO THEM.... dont even bother messen with it!!!!!
