NEW HEADUNIT NOT WORKING!!!!
ok my new dual xdvd8183 was working perfectly asnd then when i tried to ground the dvd wire it wont work now...... like when i start the car it says welcome and lights up but then like instantly it says goodbye and wont turn back on so apparently its getting power....does anyone know whats up with it???
It might be detecting a short in one of the speaker wires and shutting down. If all else fails, try it out of the car by connecting a source of 12 volts (e.g. a spare car battery with a fuse) (+) to the red and yellow wires, ground to the (-) and nothing else connected.
Well if it was working before he grounded the dvd cable then it could be something there. Try to run it with the normal unit ground connected and not the dvd cable, make sure thats ok, then go from there. At least you will know that it's something with the dvd ground.
ORIGINAL: mk378
hey just so you know, the dvd ground ondual radios has to see a sequence of grounds and no ground, so you absolutely have to run a switch in line with that wire. it explains the sequence in the manual though. its really not difficult to do
o is that why theres 2 ground wires theres the one thes directly connected to the head unit for the e brake and theres a nother one in the harness that suppost to go to the brake light or some thing like that
ALSOO does anyone know how to fix a shored speaker wire if thats the problem
