NEW HEADUNIT NOT WORKING!!!!
Old Nov 7, 2007 | 05:13 AM
finnstang's Avatar
Default RE: NEW HEADUNIT NOT WORKING!!!!
If a speaker wire is shorted, the easiest way to fix it would be to just run a new wire for the shorted one. You can look at the connection points at the headunit and the speaker itself, but if it isn't somewhere obvious, it will be simpler to replace it than to search it out.
Old Nov 7, 2007 | 06:18 AM
basbal123's Avatar
dang ok
Old Nov 7, 2007 | 06:24 AM
basbal123's Avatar
sorry for the retarded question but how do you find where the short is
Old Nov 7, 2007 | 10:47 AM
Sigracer10's Avatar
ORIGINAL: basbal123
o is that why theres 2 ground wires theres the one thes directly connected to the head unit for the e brake and theres a nother one in the harness that suppost to go to the brake light or some thing like that
ALSOO does anyone know how to fix a shored speaker wire if thats the problem
one is the ground for the e-brake, which can just be wired to a switch that goes to a ground. the other wire is for the reverse light, so that if you have a rear view camera, it will automatically switch over when the car is in reverse. this is optional, and can be pulled from the light itself in the back, or you can follow the wire up to the front and tap it there, either one.
Old Nov 8, 2007 | 04:40 AM
basbal123's Avatar
does anyone know how to locate where the short is???
Old Nov 8, 2007 | 06:52 AM
First you need to know if there is a short at all. If there is one, almost always it is going to be where you spliced wires to install aftermarket equipment.
Seriously at this point I'd suggest you pull the HU out of the car and put it on a table with a battery and see if it will come on and stay on with no speakers connected. This will also let you test the operation of the ebrake wire and determine how to connect it so DVD's will play.
Old Nov 8, 2007 | 03:32 PM
basbal123's Avatar
ok so just use a car battery
chloiebear21
Dec 24, 2012 11:46 PM
Juans_MX3
Apr 7, 2010 03:38 PM
gunaa
Oct 22, 2009 11:36 AM
chrisroug
Oct 2, 2006 11:36 AM
ballplaya4eva07
Mar 29, 2005 02:30 AM
