one speaker
Old Feb 11, 2007 | 04:27 PM
megafandrew's Avatar
Default one speaker
hey , i need some answers quick! I just hooked up my head unit and the left speaker will not work, but the right one is, i used the factory wiring, i had no choice as someone snipped all the wires before i had the car! Anyways, what could be causing this left speaker problem, bad speaker(its the original stock one, but it worked before i took out the old head unit) or wiring? the wiring is with bullet connectors
Old Feb 11, 2007 | 04:59 PM
Carlz0r's Avatar
Default RE: one speaker
I had a similar problem. The previous owner had taken it to a shop to have his stereo installed. They butchered the wiring job. So I rewired the entire thing. Works flawlessly now.
Old Feb 11, 2007 | 05:05 PM
dam, so i wonder if its the wiring, im gonna try a new speaker in the left door to discover the problem, thanks
Old Feb 11, 2007 | 07:22 PM
Stumasters's Avatar
Grab, or borrow a tester from a local car shop, and test the wiring, if your not getting any signal to the speaker, you know you don't have anything comming through the wires, then pull the head unit and test the connections there.
If the power is at the head unit, your problem lies in the wiring somewhere, most likely behind the dash.
Old Feb 11, 2007 | 10:03 PM
thanks for that advice, well i did my little test with the new speaker and it worked! for a few seconds, and then i noticed, as i move the speaker around while connected, it will go in and out of working, so i pulled some more of the stock wire out of the door and noticed it started to work, and that there is connections in there, bullet connectors, so mabey these are loose, ill have to look at those wires this friday as i work all week and will have no time, so i think its just something loose in the door,, nothing major, i know the speaker will woork now, i just have to tighten up the connection, any suggestions?? should i snip the bullets out and solder the wires directly(the stock ones)??
Clean_Civic_98
Sep 23, 2010 06:15 PM
cowsgonemadd3
Feb 20, 2008 06:30 PM
Bostonhoodhop
May 18, 2007 02:13 PM
windcalmer
Feb 12, 2007 12:59 PM
