radio '05 civic si
Old Jan 23, 2007 | 05:13 PM
samurai81's Avatar
Default radio '05 civic si
what do i have to pull off to get my stero out of my 05 civic si
Old Jan 26, 2007 | 09:36 PM
B1's Avatar
B1
Default RE: radio '05 civic si
the cover around the cd player pops off, its in there pretty tight. take a trim pannel popper or a flat head screw driver and pop it off, be carefull tho or it will leave marks.
Old Jan 26, 2007 | 10:02 PM
Misha's Avatar
B1, I wonder if you ever did this., and how your car survived if you did.
According to the service manual:
- make sure you have anti-theft code for the radio
- remove glove box (unscrew two bolts #32)
- pry shifter panel from inside out, accesing through the glove box opening
- unscrew the shifter **** and remove shifter panel with boot (# 13)
- remove two bolts (#31)holding the lower part of the radio panel.
- pull out the whole radio panel (#7 plus #11)
- unsrew and remove radio
See this pic for iilustration and numbers - sorry, the best I could find on the net...
Old Jan 26, 2007 | 11:53 PM
Ben's Avatar
Ben
Misha you can pop the trim off around the radio, take the bottom cd storage compartment out, and you'll be able to pull the radio out, I have done this and also got the code for the cd player. And actually, my bottom tray comes out on a regular basis so somebody broke it, but i'm pretty sure you can take that trim off around the cd storage area and head unit and get to the screws, undo screws before you start yanking.
Old Jan 27, 2007 | 12:29 AM
Misha's Avatar
Well, than my bad bashing the guy. []
Still think shop manual gives - mmmm - safer way. In terms of possibility of breaking something...
Old Jan 27, 2007 | 11:06 AM
KarTuneMan's Avatar
Bottom trim around the center console...then the two screws UNDER the radio, then you carefully pull the whole radio, and heater controls out together. Try and use a teflon, or plastic tool to pry with, not a flat tip screw driver....your DASH WILL SUFFER THE WRATH.
Old Jan 27, 2007 | 11:10 AM
KarTuneMan's Avatar
OOPS....did NOT read very carefully.....I didn't see Si
Sorry, please forgive me....PLEASE!
Old Jan 27, 2007 | 12:10 PM
Ben's Avatar
Ben
ORIGINAL: Misha
I'd just go by the maual because I don't want to be held accountable if he does something wrong and breaks his dash.
Fast Bob
May 25, 2014 02:15 PM
WKD_DRGN
Sep 12, 2010 04:28 PM
velvetmaggot
Aug 18, 2010 06:02 AM
mr honda
Aug 25, 2007 09:31 PM
OCH Orange County Honda
Jul 3, 2006 05:40 PM
