signal lights
That's for if you use LED turn signal bulbs. The best way to do it though is with an LED flasher relay. The problem is that since the LEDs require such little power, the relay "thinks" they are burnt out and flashes them rapidly. Load resistors or a LED flasher relay solve this problem. But you only need it for LED turn signal bulbs, not regular ones.
Seth
Nov 6, 2011 03:14 PM
