SRS light
Old May 19, 2007 | 09:05 AM
point break 92's Avatar
Default SRS light
yooooo!! alright, i got my honda stock in january and when i got it, it had on that god forsaken SRS light if i take out the cluster, it's supposed to have the little light behind the tach that can be removed...negative, there is no light that can be removed everything else has one but that one (which is what i care about) so anyone have any hints?! clues?! people i gotta go see?
Old May 19, 2007 | 09:41 AM
blackmetal619's Avatar
Default RE: SRS light
I believe that they dont want you messing with it for a reason, considering it is a safety feature
Old May 25, 2007 | 07:10 PM
jeff948594's Avatar
or the all mighty peice of electrical tape.could cover that up
"electrical tape, keeping you in the dark about the condition of your car since 1985"
Old May 25, 2007 | 08:27 PM
01civicsed's Avatar
if the light is on you need to take that car to the shop and get them to fix your "SRS" because the light being on all the time means the "SRS" systems is unoperational. so you might want to have that looked at. if the problem is fixed the light will go off and then you can remove the electrical tape.
fivebells
Aug 9, 2014 06:10 PM
houstonwide
Nov 17, 2005 09:57 PM
vmf
Aug 1, 2005 11:43 AM
Josh1122
May 4, 2005 05:50 PM
ettrump
Feb 23, 2005 05:28 PM
