sub amp match?
Old Mar 20, 2007 | 02:29 PM
03civiclxcoupe's Avatar
Default sub amp match?
amp - 500 watts x 1 at 2 ohms
http://www.crutchfield.com/S-oAq8wzS...p;I=489AP1000M
sub - dual 2 ohm voice coils 75-500watts rms
http://www.crutchfield.com/S-oAq8wzS...mp;I=575P3D212
like i said before imnot good with the ohms and wattage when it comes to subs....will these work out right...if so how do i wire them
Old Mar 20, 2007 | 06:15 PM
Stumasters's Avatar
Default RE: sub amp match?
If your getting 1 sub, you don't want a 2-ohm dual, you want a 4-ohm dual, it will wire up to 2 ohms.
A dual 2 ohm sub will wire up to 4, which means less overall power from your amp.
If you get a single voice coil sub, 2-ohms is fine, it will stay at 2-ohms when you wire it up.
Heres the wire up for a single Dual 4-ohm http://www.crutchfieldadvisor.com/le...ono_1-4ohm-DVC
Old Mar 20, 2007 | 07:06 PM
so if i get that amp cuz i want about 500 watts of bas torught one sub i get a single voice coil 2 ohm sub
Old Mar 21, 2007 | 12:48 AM
05reverb's Avatar
you can get a single coil 2 ohm, or a dual 4ohm coil. the alpine type-r has a rating of 500watts rms and you can get it in dual 4 ohms voice coils, thats the sub im running and love it. I don't know about that model rockford you are looking at, but the last model punch 3 had really sloppy bass, i prefer the alpine type-r (cleaner, tight bass), but thats just my opinion. plus it is the same price http://www.crutchfield.com/S-53Qqbrr...p;i=500SWR1242
Old Mar 21, 2007 | 07:27 AM
Stumasters's Avatar
hes right, single 2 ohm or dual 4, only way I would ever sell a system to someone.
There's just no point in running 4 wire-ups, unless you have an amp you want to run cooler, and money to waste.
Old Mar 21, 2007 | 07:40 AM
FlipHKD720's Avatar
mono amps always sound good if youre just runnin one sub.
windcalmer
Aug 4, 2007 01:30 AM
03civiclxcoupe
May 4, 2007 06:43 AM
Polygamy16
May 3, 2006 09:15 AM
PhatCivic01
Mar 6, 2006 12:34 AM
PhatCivic01
