SUB BOX HELP
Ok i'm trying to find a custom trun corner sub box for a 2005 ex 4 door i have two 10's i want in the corners so i can still access the fold down seat if anyone knows where i can find a small 10 sub box carpeted let me know
Youll love 3/4 MDF. Its good stuff. IF you can get a hold of applewood do it but if you on a budget, go with the MDF. Dont forget, once you build the box, run caulk on the cracks and run your finger down to seal all thae cracks, that way you will have a nice deadend, tight, sealed box. If its gonna be your first box, forget bass ports. Sealed boxes handle pressure better if done right. The subs will also be suspended better and are very less likely to bottom out on you.
ORIGINAL: remington870_20ga
Youll love 3/4 MDF. Its good stuff. IF you can get a hold of applewood do it but if you on a budget, go with the MDF....
I never heard that before. Does it finish nicely or is it like pine. Might be interesting to use on home speaker enclosures if it does finish nicely.
