sub box and wiring question
Old Apr 22, 2007 | 01:26 AM
97_ex's Avatar
Default sub box and wiring question
i'm gonna put a 15" dvcsoundstream in spare tire area... anyone know how to measure a box and tell how much air space is in there?i need 2.0-3.5 square feet of air space for this sub.and how will i wire this sub to a mono block class d amp @ 2ohms? thanks!
Old Apr 22, 2007 | 09:57 AM
civicduty96's Avatar
Default RE: sub box and wiring question
take your internal dimemsions - length x width x heidth,, then divide the total by 1728 that will give you your air space in cubic ft ,,,,
and as far as wiring it needs to be a dual 4 ohm to get a 2 ohm load, you just wire it in paralell pos from coil 1 to pos from coil 2, neg from coil 1 to neg to coil 2
Old Apr 22, 2007 | 10:01 AM
the727kid's Avatar
Ported or sealed?
Either way you figure the external dimensions and subtract 1.5" from each measurements, multiply all together and divide. Then if its ported figure out how big your port it.
Old Apr 22, 2007 | 02:39 PM
http://www.bcae1.com/spboxnew2.htm
Old Apr 22, 2007 | 04:59 PM
civic96lx's Avatar
make sure to add in the displacement of the woofer..
Old Apr 22, 2007 | 06:27 PM
97_ex's Avatar
thanks all!
TrAvMaNFTW
Apr 18, 2011 07:22 AM
EJsAllDay
Feb 26, 2007 09:22 AM
ryank327
Jan 25, 2007 06:32 PM
PhatCivic01
Mar 6, 2006 12:34 AM
PhatCivic01
