Sub Help ?!?!?!?
Old Mar 27, 2008 | 12:36 PM
iPhoKinG_lof_mii_EX's Avatar
Default RE: Sub Help ?!?!?!?
well i haven't tried to wire it yet cuz its raining. Nd rain n electricity dont mix.... so ima try to wire it how 93civic said n see how that goes.... i'll post the result as sson as im done.
Old Mar 27, 2008 | 05:48 PM
logand5's Avatar
If ur confused here's a good site to look up wiring diagrams and other car audio stuff http://www.the12volt.com/caraudio/wo...igurations.asp
Old Mar 28, 2008 | 05:09 PM
Mr. B's Avatar
The only part of what I said that I would take back is the "Vice Versa" phrase. Actually, the Pos lead of one sub is connected to the amp, the negative lead of the other sub is connected to the amp. This leaves us with one positive and one negative that need to be wired to eachother. That's how you wire voice coils in series, it's the only way, and it's what you need to do.
Crutchfield's cusomter support is with me on this one:
http://www.crutchfield.com/learningc...F4%2Dohm%5F2ch
But hey! Ok. Wire two 4-ohm voice coils in paralell to your BRIDGED amplifier and see what happens
Or listen to me, wire it in series and keep your amplifier up and running... Granted, your amp will run at 4 ohms, which won't exploit it's maximum output - But at least it won't turn into charcoal.
You're going to wire your voice coils paralell, turn it on, and it will A) Sound like ****, or B) Flip the protection circuit when you try to crank the gain beyond 30%.
Why don't you make it easy for yourself. Sell that 2 channel amp on ebay for $80 or whatever and buy a mono amp that's actually meant for a DVC Subwoofer.
[IMG]local://upfiles/30116/77BF6CA75F2F41C59AB3446DBD90F26E.jpg[/IMG]
Old Mar 28, 2008 | 05:17 PM
thx... first i gotta save up for tha amp.... 1 last question how many watts do u recommend for the sub... n around how much will it cost me?
windcalmer
Aug 4, 2007 01:30 AM
Polygamy16
May 3, 2006 09:15 AM
PhatCivic01
Mar 6, 2006 12:34 AM
PhatCivic01
yonu
Jun 21, 2005 07:04 PM
