Tachometer delayed?
Old Apr 19, 2014 | 07:44 PM
Wawanesa5speed's Avatar
Default Tachometer delayed?
Hello. I have a 1995 civic ex with a swapped turbo b18b1 engine. I recently wired a tachometer and when I drive the car the tachometer is delayed. The needle moves slowly and takes about a half a second to move after the throttle is pushed down. The stock tacho in the cluster still works great and moves sharply. Why is my new tach moving a slowley? Thanks.
Old Apr 23, 2014 | 10:38 AM
Why not just continue to use the tach in the gauge cluster? Why do you need two tachs to look at?
Old Apr 23, 2014 | 03:55 PM
The dash cluster was damaged, speedometer fuel meter ect, not only did then not work but the cluster had a lot of scraches ect. only dial that worked was the tach. so instead of replacing the cluster I wanted to go for something alittle nicer with aftermarket gauges. Tach was the first wired. I just kept the cluster tach in to see how close the readings would be. But the aftermarket one is about a second slower.
n2stc
Jun 14, 2010 06:17 PM
rgimenez007
Feb 16, 2009 11:53 AM
colby_666
Jul 26, 2008 11:56 AM
reverendwallis
Mar 12, 2008 10:05 AM
91SIHB
Nov 28, 2007 07:04 AM
