what settings should i put these knobs at?
Old Apr 9, 2008 | 07:54 AM
gooberguy's Avatar
Default what settings should i put these ***** at?
maybe even a quick explanation of what they mean
Old Apr 9, 2008 | 12:45 PM
Default RE: what settings should i put these ***** at?
Start by reading the manual that came with the unit. Most of these are for fine-tuning purposes and you don't need to worry about them just to hear something.
This amp appears to be designed specifically to drive subwoofers, with a pass thru for another amp to drive one set of speakers. If you have a higher end head unit designed for subwoofers, you can make almost all adjustments there. In that case I'd set the dials on the amp as follows:
Gain : halfway
Phase : zero
Subsonic: 20
Low pass: 250
Bass Boost: zero
This sets it up so basically the subwoofer will just get whatever comes out of the head unit's sub outs, the amp will work about like a conventional amp with no controls on it other than gain.
Now if you want to use the crossover feature it gets more complicated.
B!@ckBoYwiTaC!v!c
Nov 13, 2006 09:09 AM
Faithbleed
Oct 14, 2006 09:20 PM
ThisWay84
Sep 18, 2006 03:52 AM
sugerbear008
Nov 16, 2005 10:04 AM
plainzwalker
Oct 12, 2005 08:58 PM
