need help dudes
Old Aug 15, 2007 | 12:07 AM
steveabbott's Avatar
Default need help dudes
ok i have just got photoshop cs2 recently (i have been using paint.net for all my previous chops) but i can't fricken figure out how to make a straight line.. like on ms paint you can just draw and a line come and if you want it to curve you click the curvey one and on paint.net you just click the line tool and then you click and drag and then you can click and drag little points on the line to adjust the curvy ness to it.. on photoshop when i try makina line with the line tool it puts eachl ine into a new layer and creates some vector mask thing and links two thingys together .. and all i wanna do is be able to take that line and just draw a straight line normally like on ms paint and paint.net.. anybdoy know what im talkin about and anybody can help me??? i've been tryin to figure it out for so long now~!!!?![:@]
Old Aug 15, 2007 | 12:50 AM
alpeffers's Avatar
Default RE: need help dudes
try taking the paintbrush, press and hold shift, click once, move the mouse to where you want yer line to end, and click again... I think thats how it works... if that doesn't work... take the box selecty tooly thing... and have that go over the "line" you wanna draw, you then pop out the magic paint bucket (I think its hiding under gradient fill) and fill the selected area in... works kinda like mspaint does so awsomely
i've not touched CS2 in a fairwhile... partially cause i've been doing unix werk
best of luck, i'm sure someone knows more than me on the subject
Old Aug 15, 2007 | 09:02 AM
TBon3's Avatar
There's a line tool in your tools, it's in the same menu as the shapes.
Old Aug 15, 2007 | 10:26 AM
i know about the line tool i just can't figure out how to use it good.. i have finally got it so when i make a line it doesn't put it into a new layer but is there a way to make curved lines with it? or do i have to click in little segments to get a curve
Old Aug 15, 2007 | 11:01 AM
TBon3's Avatar
For curves use the pen tool. I think the pen tool is what you've needed all along. Search online for some pen tool tutorials. You can do just about anything with it, I've made some crazy stuff with it.
Omegared99
Feb 28, 2009 04:29 AM
StreetGlide
Feb 21, 2007 11:26 PM
3D Warrior
Aug 17, 2006 02:14 AM
smokingemcee
Feb 11, 2006 10:27 PM
anor32
Jan 25, 2006 08:54 AM
