Damn Vinyl...
so, I worked on taking off that damn vinyl today, got it all off without a problem, but now...i can't get the damn glue residue to come off... I've tried goo gone and that did nothing, so what is my next best option, i was thinking of trying rubbing compound but that would eff up my clear coat correct?
if goo gone didn't work try (strange that it didnt i use it almost everyday)
rapid remover - any sign shop will have it
wd-40 does work
gas
small amount of laquer thinner (be careful a little goes a long way)
denatured alcohol 70% or higher for the small stuff dont use it for large sections it wont do anything
at this point in the process make sure the temp. of the car is cool dont do this in the sunlight it will make it worse.
wd-40 does work
gas
did you use a bug/tar pad like this?
http://www.autogeek.net/pinsafscrub.html
Use this after spraying goo gone on your car. I just had a similar issue when doing my girlfriends car. Worked like a charm
